No Pim Neighbor with MVPNs
Answered Question
Sep 21st, 2009
PE1 is non SAFI capable running(12.3.16a), RR1 and PE2 are SAFI capable(12.2.31.SB11
why isn't my RR "dumbing down the update" to PE1, is anyone aware of any bugs in either IOS?
Correct Answer by Laurent Aubert about 7 years 7 months ago
Please clear the session and check with the debugs if the RR is sending the update to PE1.
Even after it's not working, last option I see before opening a TAC case is to try with SRC2 as it's the one I used in my set-up.
Laurent.
Overall Rating: 5 (1 ratings)
shivlu jain Mon, 09/21/2009 - 21:49
  • Silver, 250 points or more
If the PE is using mdt safi and route reflectors are using mdt safi & pre mdt safi in this case on PE you need to activate the ipv4 mdt for both the route reflectors so that PE can send the updates to RR1 with mdt safi and for RR2 it sends the update with extended 2:65500:1 community. In short we can upgraded RR1 is backward compatabile to the PE with respect to the mdt. Only one thing which we need to take is that to enable mdt safi for the non mdt PE.
Please refer the full document
http://shivlu.blogspot.com/2009/02/upgradation-of-rr-to-mdt-safi.html
regards
shivlu jain
lbrooker Mon, 09/21/2009 - 21:58
no the topology is
PE1 = MDT Safi Capable 122-31.SB11
PE2 = extended community 123-16a
RR(only 1 RR)= MDT SAFI Capable 122-31.SB11
shivlu jain Mon, 09/21/2009 - 22:20
MDT safi is used for mainly MVPN customers. If you are not going to activate the neighbor under ipv4 mdt in RR then it will dump the updates. If the mdt is activated under RR towards the non-mdt safi, it will not dump the updates.
regards
shivlu jain
lbrooker Tue, 09/22/2009 - 15:43
Thats the problem! The RR is configured for both vpnv4 and mdt towards both PEs, but the PE that doesn't support the MDT SAFI is not receiving it as a type 2 RD. Its like the RR is "not dumbing down" the new type MDT to old type 2 to the non MDT capable router. Hence why I think this is a bug on the RR. Its IOS is 122-31.SB11
Cheers
Mat
shivlu jain Wed, 09/23/2009 - 04:01
try to change the ios and let us know.
regards
shivlu jain
lbrooker Wed, 09/23/2009 - 05:49
OK changed the IOS on the RR and PE2 to
c7200p-spservicesk9-mz.122-33.SRC4
IOS of PE1 is c7200-p-mz.123-21 still no joy although i get an interesting debug message from debug ip bgp vpnv4
*Sep 23 05:17:59.111: vpn: sourced prefix 2:20:1:203.194.30.63/32 not in any VRF, not allocating local label
*Sep 23 05:17:59.315: vpn: sourced prefix 2:20:1:203.194.30.63/32 not in any VRF, not allocating local label
what does the above mean?
shivlu jain Wed, 09/23/2009 - 07:54
It means that the PE1 is receiving the routes with extended community because it doesn't support mdt safe, but it is rejecting the route because not able to find any vrf for the same.
regards
shivlu jain
lbrooker Thu, 09/24/2009 - 20:40
Hi Shivlu
I actually think its rejecting the route because of the RD? As if you put that IP address on an interface in that vrf it still fails.....have you managed to get this to work with RR supporting MDT SAFI sending updates to non supporting and supporting MDT SAFI PEs? I am looking at maybe an import map on the vrf configuration :o)
lbrooker Thu, 09/24/2009 - 20:48
actually that doesn't work either. I know my config is great so looking at IOS' if you have had this runnning then I would love to know how.
lbrooker Thu, 09/24/2009 - 21:16
Yeah I have already read this, but was just wondering if you had it working as well?
Laurent Aubert Fri, 09/25/2009 - 06:08
  • Cisco Employee,
It's a locally generated update. If 203.194.30.63 is the address of PE1 then this is the update generated by PE1.
Do you have send-community both configured under the MDT AF ?
Laurent.
lbrooker Sun, 09/27/2009 - 17:59
Hi Laurent, welcome to the party :o)
well from the PE point of view b/c its non SAFI the connection is via VPNv4 but both is stipulated. I think i read in the whitepaper that cisco released they say if you have a hybrid environment then you must have both stipulated on the RR, so in answer to your question yes we do have it.
PE1 is non SAFI shows no PIM neighbor
PE2 is SAFI and show one PIM neighbor(which happens to be PE1)
Cheers
lbrooker Sun, 09/27/2009 - 18:14
output from sh ip pim vrf "" neighbor command
PE2
sh ip pim vrf mpls neighbor
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
P - Proxy Capable, S - State Refresh Capable
Neighbor Interface Uptime/Expires Ver DR
Address Prio/Mode
203.194.30.63 Tunnel0 2d22h/00:01:28 v2 1 / DR S
PE1
PIM Neighbor Table
Address
Laurent Aubert Mon, 09/28/2009 - 07:25
  • Cisco Employee,
I tested it and it's working fine for me:
PE1--RR--PE2
PE1 running 12.3(16a), non-MDT aware L0= 10.1.2.1
RR and PE2 running 12.2(33)SRC2. MDT aware. L0: 100.100.2.1 and 10.1.2.2
Debug on PE2:
*Sep 28 15:10:07.165: %BGP-5-ADJCHANGE: neighbor 100.100.2.1 Up
*Sep 28 15:10:07.169: BGP:from:3 to:3 update format 2:2001:10.1.2.1/32 MDT grp 232.0.0.1 pfxptr->masklen 128
*Sep 28 15:10:13.541: BGP(4): ... start import cfg version = 5BGP: bpath->mdt 0xE8000001 232.0.0.1
*Sep 28 15:10:14.381: BGP:from:3 to:3 update format 2:2000:10.1.2.2/32 MDT grp 232.0.0.1 pfxptr->masklen 128
Debug from RR:
00:05:56: BGP(3): 10.1.2.1 send UPDATE (format) 2:2000:10.1.2.2/32, next 10.1.2.2, metric 0, path Local, extended community RT:2:20 MDT:2:232.0.0.1
Debugs from PE1:
AS2-PE20#
*Sep 28 15:15:34.595: BGP: Incoming path from 100.100.2.1
*Sep 28 15:15:34.595: BGP: Accepted path from 100.100.2.1
*Sep 28 15:15:34.595: BGP: Incoming MDT from 100.100.2.1 : present
*Sep 28 15:15:34.595: BGP: Inform multicast system about mdt 232.0.0.1 from router-id 10.1.2.1 with next-hop 10.1.2.1 : present
*Sep 28 15:15:34.595: BGP VPNV4: MPLS label changed for prefix 2:2:2001:10.1.2.1/32
*Sep 28 15:15:34.595: BGP VPNV4: bestpath from neighbor 100.100.2.1 nexthop 10.1.2.1 new outlabel exp-null
AS2-PE20#
AS2-PE20#sh ip pim mdt bgp
Peer (Route Distinguisher + IPv4) Next Hop
MDT group 232.0.0.1
2:2:2001:10.1.2.1 10.1.2.1
AS2-PE20#
AS2-PE20#sh ip mroute
(10.1.2.1, 232.0.0.1), 00:14:09/00:02:58, flags: sTIZ
Incoming interface: Ethernet0/0, RPF nbr 192.168.2.5
Outgoing interface list:
MVRF MVPN-IAS-B, Forward/Sparse, 00:14:09/00:02:10
(10.1.2.2, 232.0.0.1), 00:31:52/00:03:27, flags: sT
Incoming interface: Loopback0, RPF nbr 0.0.0.0
Ethernet0/0, Forward/Sparse, 00:09:52/00:03:21
(*, 224.0.1.40), 00:32:02/00:02:30, RP 0.0.0.0, flags: DCL
Incoming interface: Null, RPF nbr 0.0.0.0
Loopback0, Forward/Sparse, 00:32:02/00:02:20
Ethernet0/0, Forward/Sparse, 00:31:57/00:02:30
AS2-PE20#sh ip pim vrf MVPN-IAS-B neighbor
PIM Neighbor Table
Address Prio/Mode
10.1.2.1 Tunnel0 00:17:15/00:01:41 v2 1 / S
AS2-PE20#
Can you check how the update is propagated from PE2 to PE1 ? Also please share your complete configuration.
Laurent.
lbrooker Mon, 09/28/2009 - 15:38
Hi Laurent
Many thanks for this.
OK I am using PIM SSM and here is the config attached. each router is linked by a 7600 router that performs IGP connectivity and PIM signalling.
lbrooker Mon, 09/28/2009 - 16:07
Hi Laurent
Forgot to attach debugs from BGP updates
PE1)
wsr17-kent-syd-test#clear ip bgp *
*Sep 28 15:02:20.484: %BGP-5-ADJCHANGE: neighbor 203.194.30.62 Down User reset
*Sep 28 15:02:27.300: vpn: bgp_vpnv4_bnetinit: 20:1:172.17.20.1/32
*Sep 28 15:02:30.176: %BGP-5-ADJCHANGE: neighbor 203.194.30.62 Up
*Sep 28 15:02:30.176: BGP: Incoming path from 203.194.30.62
*Sep 28 15:02:30.176: vpn: bgp_vpnv4_bnetinit: 20:1:172.17.20.3/32
*Sep 28 15:02:30.176: BGP: Accepted path from 203.194.30.62
*Sep 28 15:02:30.176: vpn: bgp_vpnv4_alloc_tag route_tag_change for mpls:172.17.20.1/255.255.255.255
*Sep 28 15:02:30.176: vpn: tag_vpn_find_route_tags: 20:1:172.17.20.1
*Sep 28 15:02:30.176: vpn: intag=1886, outtag=aggregate(mpls), outtag owner=BGP
*Sep 28 15:02:40.196: %SEC-6-IPACCESSLOGS: list ssm-range permitted 239.232.0.17 1 packet
*Sep 28 15:02:42.612: vpn: tag_vpn_find_route_tags: 20:1:172.17.20.3
*Sep 28 15:02:42.612: vpn: intag=vpn-route, outtag=833, outtag owner=BGP
*Sep 28 15:03:27.320: vpn: bgp_vpnv4_bnetinit: 2:20:1:203.194.30.63/32
*Sep 28 15:03:27.320: vpn: bgp_vpnv4_alloc_tag route_tag_change for mpls:172.17.20.1/255.255.255.255
*Sep 28 15:03:27.320: vpn: tag_vpn_find_route_tags: 20:1:172.17.20.1
*Sep 28 15:03:27.320: vpn: intag=1886, outtag=aggregate(mpls), outtag owner=BGP
*Sep 28 15:03:27.320: vpn: sourced prefix 2:20:1:203.194.30.63/32 not in any VRF, not allocating local label
*Sep 28 15:03:27.932: vpn: sourced prefix 2:20:1:203.194.30.63/32 not in any VRF, not allocating local label
RR1)
rrv01-kent-syd-test#clear ip bgp vpnv4 unicast 20
5d19h: %BGP_SESSION-5-ADJCHANGE: neighbor 203.194.30.61 VPNv4 Unicast topology base removed from session User reset
5d19h: %BGP_SESSION-5-ADJCHANGE: neighbor 203.194.30.61 IPv4 MDT topology base removed from session User reset
5d19h: %BGP-5-ADJCHANGE: neighbor 203.194.30.61 Down User reset
5d19h: %BGP_SESSION-5-ADJCHANGE: neighbor 203.194.30.63 VPNv4 Unicast topology base removed from session User reset
5d19h: %BGP_SESSION-5-ADJCHANGE: neighbor 203.194.30.63 IPv4 MDT topology base removed from session User reset
5d19h: %BGP-5-ADJCHANGE: neighbor 203.194.30.63 Down User reset
5d19h: BGP(3): 3 Inform multicast system about mdt [ #0:203.194.30.61, 0.0.0.0] from router-id 0.0.0.0 with next-hop 0.0.0.0 : absent
5d19h: BGP(3): 3 Inform multicast system about mdt [ #0:203.194.30.63, 0.0.0.0] from router-id 0.0.0.0 with next-hop 0.0.0.0 : absent
5d19h: %BGP-5-ADJCHANGE: neighbor 203.194.30.61 Up
5d19h: BGP(4): Incoming path from 203.194.30.61
5d19h: BGP(3): 3 Inform multicast system about mdt [ #0:203.194.30.61, 239.232.0.17] from router-id 203.194.30.61 with next-hop 203.194.30.61 : present
5d19h: %BGP-5-ADJCHANGE: neighbor 203.194.30.63 Up
5d19h: BGP(4): Incoming path from 203.194.30.63
5d19h: BGP(3): 3 Inform multicast system about mdt [ #0:203.194.30.63, 239.232.0.17] from router-id 203.194.30.63 with next-hop 203.194.30.63 : present
PE2)
*Sep 29 02:46:44.637 EST: vpn: free local label 1048577 for remote prefix mpls:172.17.20.1/32BGP: bpath->mdt 0xEFE80011 239.232.0.17
*Sep 29 02:46:44.637 EST: BGP(3): 3 Inform multicast system about mdt [%Rx:203.194.30.63, 239.232.0.17] from router-id 203.194.30.62 with next-hop 203.194.30.63 : present
*Sep 29 02:46:44.637 EST: BGP:from:3 to:3 update format 20:1:203.194.30.63/32 MDT grp 239.232.0.17 pfxptr->masklen 128
*Sep 29 02:46:44.637 EST: BGP(4): Revise route installing 1 of 1 routes for 172.17.20.1/32 -> 203.194.30.63(mpls) to mpls IP table
*Sep 29 02:46:44.637 EST: vpn: get path labels: 20:1:172.17.20.1/255.255.255.255
*Sep 29 02:46:44.637 EST: vpn(4): inlabel=nolabel, outlabel=1886, outlabel owner=BGP
*Sep 29 02:46:44.637 EST: vpn(4): Announce labels to IPRM mpls:172.17.20.1/32 gw 203.194.30.63 inlabel=nolabel, outlabel=1886
Laurent Aubert Mon, 09/28/2009 - 19:31
  • Cisco Employee,
I don't see PE1 receiving any MDT updates from the RR.
Can you run debug ip bgp vpnv4 unicast updates on both PE1 and RR and then do a clear ip bgp 203.194.30.63 soft out on the RR ?
Could you also run SRC2 on the RR so we will have the same set-up.
Laurent.
lbrooker Mon, 09/28/2009 - 19:58
OK debugs are here, I am running SRC4, are you sure you want me to downgrade to SRC2?
RR1)
rrv01-kent-syd-test#clear ip bgp 203.194.30.63
5d23h: %BGP_SESSION-5-ADJCHANGE: neighbor 203.194.30.63 VPNv4 Unicast topology base removed from session User reset
5d23h: %BGP_SESSION-5-ADJCHANGE: neighbor 203.194.30.63 IPv4 MDT topology base removed from session User reset
5d23h: %BGP-5-ADJCHANGE: neighbor 203.194.30.63 Down User reset
5d23h: BGP(3): 3 Inform multicast system about mdt [ #0:203.194.30.63, 0.0.0.0] from router-id 0.0.0.0 with next-hop 0.0.0.0 : absent
5d23h: %BGP-5-ADJCHANGE: neighbor 203.194.30.63 Up
5d23h: BGP(4): Incoming path from 203.194.30.63
5d23h: BGP(3): 3 Inform multicast system about mdt [ #0:203.194.30.63, 239.232.0.17] from router-id 203.194.30.63 with next-hop 203.194.30.63 : present
PE1
*Sep 28 19:16:20.923: %BGP-5-ADJCHANGE: neighbor 203.194.30.62 Down Peer closed the session
*Sep 28 19:16:34.307: %BGP-5-ADJCHANGE: neighbor 203.194.30.62 Up
*Sep 28 19:16:34.307: BGP: Incoming path from 203.194.30.62
*Sep 28 19:16:34.307: vpn: bgp_vpnv4_bnetinit: 20:1:172.17.20.3/32
*Sep 28 19:16:34.307: BGP: Accepted path from 203.194.30.62
*Sep 28 19:16:34.407: vpn: sourced prefix 2:20:1:203.194.30.63/32 not in any VRF, not allocating local label
*Sep 28 19:16:48.579: vpn: tag_vpn_find_route_tags: 20:1:172.17.20.3
*Sep 28 19:16:48.579: vpn: intag=vpn-route, outtag=868, outtag owner=BGP
Laurent Aubert Mon, 09/28/2009 - 20:18
  • Cisco Employee,
Ok, I triple checked everything ;-) and I think I found why it's not working.
You didn't configure route-reflector client in the MDT AF. You should have on the RR:
address-family ipv4 mdt
neighbor 203.194.30.61 activate
neighbor 203.194.30.61 send-community both
neighbor 203.194.30.61 route-reflector-client
neighbor 203.194.30.63 activate
neighbor 203.194.30.63 send-community both
neighbor 203.194.30.63 route-reflector-client
exit-address-family
So the update received from PE2 will be propagated to PE1.
Let me know if it's working after the change.
Laurent.
lbrooker Mon, 09/28/2009 - 20:31
I have added the config on the RR in teh MDT family and its still not working
Correct Answer
Laurent Aubert Mon, 09/28/2009 - 20:36
  • Cisco Employee,
Laurent.
lbrooker Mon, 09/28/2009 - 20:40
nope still have the same problem
router bgp 20
bgp router-id 203.194.30.62
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 10.2.0.5 remote-as 10
neighbor 10.2.0.5 description ebgp to rrv01.syd01.test
neighbor 10.2.0.5 ebgp-multihop 255
neighbor 203.194.30.61 remote-as 20
neighbor 203.194.30.61 description BDR02-SYD
neighbor 203.194.30.61 update-source Loopback0
neighbor 203.194.30.63 remote-as 20
neighbor 203.194.30.63 description WSR17-SYD
neighbor 203.194.30.63 update-source Loopback0
address-family ipv4
no synchronization
no auto-summary
exit-address-family
address-family vpnv4
neighbor 10.2.0.5 activate
neighbor 10.2.0.5 send-community both
exit-address-family
exit-address-family
lbrooker Mon, 09/28/2009 - 20:43
clear with debugs
PE1)
*Sep 28 20:02:05.867: %BGP-5-ADJCHANGE: neighbor 203.194.30.62 Down Peer closed the session
*Sep 28 20:02:17.135: %BGP-5-ADJCHANGE: neighbor 203.194.30.62 Up
*Sep 28 20:02:17.135: BGP: Incoming path from 203.194.30.62
*Sep 28 20:02:17.135: BGP: Accepted path from 203.194.30.62
*Sep 28 20:02:17.135: vpn: tag_vpn_find_route_tags: 20:1:172.17.20.3
*Sep 28 20:02:17.135: vpn: intag=vpn-route, outtag=868, outtag owner=BGP
*Sep 28 20:02:17.235: vpn: sourced prefix 2:20:1:203.194.30.63/32 not in any VRF, not allocating local label
RR1)
6d00h: %BGP_SESSION-5-ADJCHANGE: neighbor 203.194.30.61 VPNv4 Unicast topology base removed from session User reset
6d00h: %BGP_SESSION-5-ADJCHANGE: neighbor 203.194.30.61 IPv4 MDT topology base removed from session User reset
6d00h: %BGP-5-ADJCHANGE: neighbor 203.194.30.61 Down User reset
6d00h: %BGP_SESSION-5-ADJCHANGE: neighbor 203.194.30.63 VPNv4 Unicast topology base removed from session User reset
6d00h: %BGP_SESSION-5-ADJCHANGE: neighbor 203.194.30.63 IPv4 MDT topology base removed from session User reset
6d00h: %BGP-5-ADJCHANGE: neighbor 203.194.30.63 Down User reset
6d00h: BGP(3): 3 Inform multicast system about mdt [ #0:203.194.30.61, 0.0.0.0] from router-id 0.0.0.0 with next-hop 0.0.0.0 : absent
6d00h: BGP(3): 3 Inform multicast system about mdt [ #0:203.194.30.63, 0.0.0.0] from router-id 0.0.0.0 with next-hop 0.0.0.0 : absent
6d00h: %BGP-5-ADJCHANGE: neighbor 203.194.30.61 Up
6d00h: BGP(4): Incoming path from 203.194.30.61
6d00h: BGP(3): 3 Inform multicast system about mdt [ #0:203.194.30.61, 239.232.0.17] from router-id 203.194.30.61 with next-hop 203.194.30.61 : present
6d00h: %BGP-5-ADJCHANGE: neighbor 203.194.30.63 Up
6d00h: BGP(4): Incoming path from 203.194.30.63
6d00h: BGP(3): 3 Inform multicast system about mdt [ #0:203.194.30.63, 239.232.0.17] from router-id 203.194.30.63 with next-hop 203.194.30.63 : present
lbrooker Mon, 09/28/2009 - 20:47
Laurent
can I see a copy of your debugs when you do a clear on your RR?
Cheers
Laurent Aubert Tue, 09/29/2009 - 07:49
  • Cisco Employee,
RR:
AS2-RR1#sh deb
IP routing:
BGP updates debugging is on for address family: VPNv4 Unicast
AS2-RR1#clear ip bgp * so
AS2-RR1#clear ip bgp * soft out
AS2-RR1#
00:04:39: BGP:from:3 to:4 update format 2:2001:10.1.2.1/0 MDT grp 232.0.0.1 pfxptr->masklen 96
00:04:39: BGP: No vrf corresponding to the MDT group 232.0.0.1 exists
00:04:39: BGP(4): 10.1.2.2 send UPDATE (format) 2:2:2001:10.1.2.1/32, next 10.1.2.1, label 0, metric 0, path Local <----- update received from PE2 translated and sent by the RR
00:04:39: BGP:from:3 to:3 update format 2:2001:10.1.2.1/32 MDT grp 232.0.0.1 pfxptr->masklen 128
00:04:39: BGP:from:3 to:4 update format 2:2000:10.1.2.2/0 MDT grp 232.0.0.1 pfxptr->masklen 96
00:04:39: BGP:from:3 to:3 update format 2:2000:10.1.2.2/32 MDT grp 232.0.0.1 pfxptr->masklen 128
00:04:39: BGP:from:3 to:4 update format 1:1011:10.1.1.1/0 MDT grp 232.0.0.1 pfxptr->masklen 96
00:04:39: BGP(4): 10.1.2.2 send UPDATE (format) 2:1:1011:10.1.1.1/32, next 1.1.12.1, label 0, metric 0, path 1
00:04:39: BGP:from:3 to:3 update format 1:1011:10.1.1.1/32 MDT grp 232.0.0.1 pfxptr->masklen 128
00:04:39: BGP:from:3 to:4 update format 1:1001:10.1.1.1/0 MDT grp 239.0.0.1 pfxptr->masklen 96
BGP: bpath->mdt 0xEF000001 239.0.0.1
00:04:39: BGP: No vrf corresponding to the MDT group 239.0.0.1 exists
00:04:39: BGP(4): 10.1.2.2 send UPDATE (format) 2:1:1001:10.1.1.1/32, next 1.1.12.1, label 0, metric 0, path 1
00:04:39: BGP:from:3 to:3 update format 1:1001:10.1.1.1/32 MDT grp 239.0.0.1 pfxptr->masklen 128
00:04:39: BGP(4): 10.1.2.1 send UPDATE (format) 2:2000:172.16.20.0/24, next 10.1.2.2, label 23, metric 0, path Local, extended community RT:2:20
00:04:39: BGP(4): 10.1.2.1 send UPDATE (format) 1:1011:172.16.1.0/24, next 1.1.12.1, label 16008, metric 0, path 1, extended community RT:1:200
00:04:39: BGP(4): 10.1.2.1 send UPDATE (format) 1:1001:10.10.10.10/32, next 1.1.12.1, label 16001, metric 0, path 1 65001, extended community RT:1:300
AS2-RR1#
00:04:39: BGP(4): updgrp 1 - 10.1.2.1 updates replicated for neighbors: 10.1.2.2
AS2-RR1#
PE1:
AS2-PE20#deb ip bgp vpnv4
Tag VPN debugging is on
AS2-PE20#
AS2-PE20#
*Sep 29 15:35:10.915: BGP: Incoming path from 100.100.2.1
*Sep 29 15:35:10.915: BGP: Accepted path from 100.100.2.1
*Sep 29 15:35:10.951: BGP: Incoming path from 100.100.2.1
*Sep 29 15:35:10.951: BGP: Accepted path from 100.100.2.1
*Sep 29 15:35:10.951: BGP: Incoming MDT from 100.100.2.1 : present
*Sep 29 15:35:10.951: BGP: Inform multicast system about mdt 232.0.0.1 from router-id 10.1.2.1 with next-hop 10.1.2.1 : present <---- Update received and processed
*Sep 29 15:35:10.951: BGP VPNV4: MPLS label changed for prefix 2:2:2001:10.1.2.1/32
*Sep 29 15:35:10.951: BGP VPNV4: bestpath from neighbor 100.100.2.1 nexthop 10.1.2.1 new outlabel exp-null
*Sep 29 15:35:10.951: BGP: Inform multicast system about mdt 232.0.0.1 from router-id 10.1.2.1 with next-hop 1.1.12.1 : present
*Sep 29 15:35:10.951: BGP VPNV4: MPLS label changed for prefix 2:1:1011:10.1.1.1/32
*Sep 29 15:35:10.951: BGP VPNV4: bestpath from neighbor 100.100.2.1 nexthop 1.1.12.1 new outlabel exp-null
AS2-PE20#
*Sep 29 15:35:10.951: BGP: Inform multicast system about mdt 239.0.0.1 from router-id 10.1.2.1 with next-hop 1.1.12.1 : present
*Sep 29 15:35:10.951: BGP VPNV4: MPLS label changed for prefix 2:1:1001:10.1.1.1/32
I'm out of idea here.. I attached my configuration for your reference.
Laurent.
lbrooker Tue, 09/29/2009 - 19:57
Mate you are a star :o) I have downgraded the IOS to SRC2 and this worked perfectly. I am so happy now. I was wondering if you could pass our findings onto the Developers at Cisco so they could do a bug scrub on SRC4. I am now working on the Inter-AS side now, if I hit a problem I will open a new conversation. Thanks for all your help again.
Laurent Aubert Wed, 09/30/2009 - 07:37
  • Cisco Employee,
I'm glad it's working now. You should anyway migrate PE1 to a release which supports MDT AF so it will make your design consistent and avoid some headache ;-)
Btw only MDT AF support Inter-AS MVPN
Laurent.
lbrooker Wed, 09/30/2009 - 14:32
reading the documentation on Inter-AS Multicast support i understand that the typ 2 is a non transitive extended community. I am going to use Cisco design option C using RRs. looks so much easier :o)
Laurent Aubert Wed, 09/30/2009 - 17:12
  • Cisco Employee,
You don't have the choice as 12.3 doesn't support PIM Vector as well.
I'm curious, why do you need to have both implementation of MDT in your network ? Everything would be much easier of all your PE's and RRs support MDT.
Laurent.
lbrooker Wed, 09/30/2009 - 20:25
we have a range of routers from 3660s, 7200s with NPE-300s :o( To nice 7600s, GSR and 7200 NPE-G2s :o) geographically spread across all of australia,
lbrooker Wed, 09/30/2009 - 23:20
just looked at the document again and noticed that if you have option B or C you must have the proxy vector command(either in the VRF or otherwise). However 123.22 or 123.16a don't support either command :o(
Laurent Aubert Thu, 10/01/2009 - 04:55
  • Cisco Employee,
PIM proxy Vector is required only if the PE loopbacks of the other AS are not redistributed into your IGP.
So if you are using option C and remote AS loopbacks are learned via BGP only then you need PIM proxy Vector.
Laurent.
lbrooker Thu, 10/01/2009 - 13:53
I will open another conversation here Laurent just im case other people are looking at this :o)
