Traffic doesn't hit the QoS policy
Sep 21st, 2009
We are using ASA - router to build up VPN tunnel base on DSL connection. On router, I added the follwoing QoS policy on the router outside port, but looks like no traffic hit the QoS on router. But on the ASA, I can see the traffic hit the QoS policy. Anyone has any ideas for this issue?
Thanks, Leo
IOS: c2800nm-advipservicesk9-mz.124-15.T7.bin
ip access-list extended lighthouse
permit ip any host 192.168.9.2
access-list 198 permit esp host X.X.X.X any
access-list 198 permit udp host X.X.X.X any eq isakmp
access-list 198 permit tcp any any eq 22
access-list 198 deny ip any any
class-map match-any lighthouse
match access-group name lighthouse
policy-map ALL-TRAFFIC
class lighthouse
priority percent 50
class class-default
fair-queue
random-detect
interface FastEthernet0/0
description connect to DSL modem
bandwidth 1024
ip address Y.Y.Y.Y
ip access-group 198 in
ip route-cache flow
duplex auto
speed auto
crypto map mymap
service-policy output ALL-TRAFFIC
xzjleo2005 Tue, 09/22/2009 - 15:00
Only one default route pointing to ISP GW. All traffic will go through VPN tunnel, including the traffic to 192.168.9.2. The F0/0 is outside interface connect to ISP DSL modem
Thanks,Leo
xzjleo2005 Wed, 09/23/2009 - 03:11
I can't see any traffic hit the acl, but I can see the traffic in netflow. That's very strange.
xzjleo2005 Wed, 09/23/2009 - 04:12
Thanks for your reply.
I tried the way you suggested and here is the show policy-map interface output. We can see a lot of traffic to be marked now, but wondering why not too much traffic to be put in the priority queue?
Thanks. Leo
AP816N0001#sh policy-map interface
FastEthernet0/0
Service-policy output: ALL-TRAFFIC
Class-map: outgo (match-any)
7446 packets, 926436 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: precedence 5
0 packets, 0 bytes
5 minute rate 0 bps
Match: ip precedence 5
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 512 (kbps) Burst 12800 (Bytes)
(pkts matched/bytes matched) 8/1520
(total drops/bytes drops) 0/0
Class-map: class-default (match-any)
140707 packets, 68075067 bytes
5 minute offered rate 25000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
exponential weight: 9
class Transmitted Random drop Tail drop Minimum Maximum Mark
pkts/bytes pkts/bytes pkts/bytes thresh thresh prob
0 127616/66283953 0/0 0/0 20 40 1/10
1 0/0 0/0 0/0 22 40 1/10
2 0/0 0/0 0/0 24 40 1/10
3 0/0 0/0 0/0 26 40 1/10
4 0/0 0/0 0/0 28 40 1/10
5 0/0 0/0 0/0 30 40 1/10
6 13091/1791114 0/0 0/0 32 40 1/10
7 0/0 0/0 0/0 34 40 1/10
rsvp 0/0 0/0 0/0 36 40 1/10
FastEthernet0/1
Service-policy input: income
Class-map: income (match-any)
7446 packets, 485157 bytes
Match: access-group name income
5 minute rate 0 bps
QoS Set
precedence 5
Packets marked 7446
124216 packets, 60574939 bytes
5 minute offered rate 23000 bps, drop rate 0 bps
Match: any
