09-21-2009 11:25 PM
hi.. :)
I have a question about ES Card. Also I consider to purchase that module as soon.
We have a plan using the es card to Router QoS.
the point is that the ES Card support all of router qos? ex) MQC, Shaping, CBWFQ..
thanks in advance.
09-21-2009 11:36 PM
Check the link it supports all what you are looking for
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES20_config_guide/SRD/bald_qos.html
regards
shivlu jain
