paolo bevilacqua Tue, 09/22/2009 - 00:20
  • Hall of Fame,
    Founding Member
Which timeout are you talking about ?
Connection timeout is like 45 secs actually.
xzjleo2005 Tue, 09/22/2009 - 02:07
It's TCP connection time out. In ASA, default setting is 1 hour. You can change it with command 'timeout conn 2:00:00'. Just want to know if there are any commands in router can change it.
Thanks. Leo
paolo bevilacqua Tue, 09/22/2009 - 03:23
  • Hall of Fame,
    Founding Member
Again, you should indicate what exact timeout are you talking about.
xzjleo2005 Tue, 09/22/2009 - 03:35
Actually our problem is the one application which base on telnet keep dropping out every 15 minutes in IPSec VPN environment (ASA to router). So I am checking if I can set the TCP connection time out in a longer value on router and ASA to resolve the issue.
Thanks. Leo
paolo bevilacqua Tue, 09/22/2009 - 03:37
  • Hall of Fame,
    Founding Member
Check the ipsec idle session timeouts.
xzjleo2005 Tue, 09/22/2009 - 16:01
Thanks for your reply.
I checked the ASA, the VPN tunnel has been up and running for more than 24 hours, so I don't believe it's tunnel up/down issue. Also all other applications are working fine except this telnet applications.
And the issue didn't happen when we used frame-relay circuit before, we just migrated to DSL VPN in last week. I added the CBWFQ on ASA and router, but it doesn't help.
Any other ideas?
Thanks. Leo
