Remote VPN Access
Sep 22nd, 2009
I have created a Remote VPN in PIX 515E 7.0 and issue is we are getting connected to the VPN but not able to access the servers sometimes
When i try connecting from my home its getting connected to VPN aswell as servers but when i try from remote office iam not able to access the servers when i connected after sometimes same is connecting
why this improper responce
its may be due to Client version
Due to some ISP
and i same heard from some of my remote users
can u suggest us why this is
Alexandro Carra... Tue, 09/22/2009 - 08:31
can you ping the remote servers when you're not able to connect? ... you may try to use transport-mode to reduce the overhead or reduce the mss on the pix.
acomiskey Tue, 09/22/2009 - 08:43
Make sure you have this command in the pix.
isakmp nat-traversal
crypto isakmp nat-traversal
If that doesn't help, post the config.
vinoth.kumar Sat, 09/26/2009 - 03:41
Thanks for your reply
yes i deployed the command and waiting for the responnce from my clients
can i know what exactly this command will do ? and
why this issue is happened without deploying this command?
