ASA: cli, ssh asdm login and VPN login with the same freeRADIUS
Sep 22nd, 2009
Hi all!
I have a problem, we are using freeradius server to authenticate the VPN users. It works fine.
Now I want authenticate the ssh, asdm users with the same radius.
The only problem is that the ASA doesn't send different attributes to the radius and in the radius I can't sort the request(VPN or SSH).
How can I set the ASA to send Service-Type attribute or something what can be usefull?
every time it sends just these attributes:
User-Name = xxx
User-Password = xxx
NAS-IP-Address = xxx
NAS-Port = xxx
NAS-Port-Type = Virtual
Cisco-AVPair = "ip:source-ip=xxx"
Calling-Station-Id = "ip:source-ip=xxx"
Have you got any idea?
ty
Gabor
jagadeeshan.s Tue, 09/22/2009 - 02:56
An alternate idea is, use "aaa authentication" for ssh & https services using your radius server.
-Jags.
Jatin Katyal Tue, 09/22/2009 - 04:29
Per my knowledge, this is not possible to configure ASA to send service-type in radius access-request.
Ques: why we need service-type attribute.The user will be authenticated without this.
NOTE: ASA does not understand the cisco-avpair = "shell:priv-lvl=15" attribute.
Just configure your ASA with following commands:
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
username password priv 15
LOCAL: This will help you to login into the ASA when freeradius is not available.
JK
hegegabor Tue, 09/22/2009 - 04:54
ok, I know how to authenticate the ssh users with radius.
The only problem is that I don't want allow VPN users to access to ssh. But if the Radius cant separate the request, it dosen't know witch type of user want to login.
(Not just service-type good for me, everything that is differs in the two auth type.)
hegegabor Tue, 09/22/2009 - 04:36
hmm, yes exactly this is what I want.
I want authentication and authorization for ssh. Still have an authentication (aaa of the VPN users) but the access-request is the same, this is the problem.
I can't separate these different type authentication.
for example:
In cisco IOS I can send vendor specific attributes to radius ("vsa send"). And here the attribute values are different.
Jatin Katyal Tue, 09/22/2009 - 05:07
You got it.
there is no command available on ASA to send vendor specific attribute.
I think you are looking for an attribute that differentiate the access-request for both the cases. Also, service-type attribute is a good catch but this will always come in radius accept so you need to configure this on the free radius server.
Service-type:
http://freeradius.org/rfc/rfc2865.html#Service-Type
JK
hegegabor Tue, 09/22/2009 - 05:33
hi.
okay I see there is no way to send specific attributes to radius, or modify it in ASA. That is what i wanted to know.
Thank you all.
BR,
Gabor
