ASA 5505 two sites, isp, public ip, L2L
Sep 22nd, 2009
Hi, have to ask, as I've struggled long with this now. We have two sites, ASA in both ends. Can configure dmz to access inside, and static address translations for the outside, and vpn-tunnel in between the two inside networks.
But we have trouble getting the two dmz's to talk to one another, plus from the inside of site A to the dmz on site B.
Surely this example must exist, and I'm just too stupid to find it?
Layout, in general
outside/Site A - dmzA(10.0.1.0) - insideA(192.168.1.0)
vpn_tunnel_2 vpn_tunnel_1
outside/site B - dmzB(10.0.2.0) - insideB(192.168.2.0)
I've tried routing f.ex. rdp from insideB to dmzA over the vpn_tunnel_1, but somehow I fail doing this.
Any pointers would be most appreciated, as services in dmzA has to be able to reach f.ex. smtp servers in dmzB
Next step for me to try is a vpn-tunnel (vpn_tunnel_2) between the two dmz's, so that services can be utilized between the two - or is this a noob idea?
cheers / Peter
Next step for me to try is a vpn-tunnel between the two dmz's, so that services can be utilized between the two - or is this a noob idea?
Layout, in general
outside - Site A - dmzA(10.0.1.0) - inside (192.168.1.0)
Overall Rating: 5 (2 ratings)
acomiskey Tue, 09/22/2009 - 04:44
  • Green, 3000 points or more
Add the traffic for the dmz's to your crypto acl.
Site A
access-list extended permit ip 10.0.1.0 255.255.255.0 10.0.2.0 255.255.255.0
access-list extended permit ip 10.0.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list extended permit ip 192.168.1.0 255.255.255.0 10.0.2.0 255.255.255.0
Site B
access-list extended permit ip 10.0.2.0 255.255.255.0 10.0.1.0 255.255.255.0
access-list extended permit ip 192.168.2.0 255.255.255.0 10.0.1.0 255.255.255.0
access-list extended permit ip 10.0.2.0 255.255.255.0 192.168.1.0 255.255.255.0
Then add the traffic to a nat 0 acl for the dmz's.
Site A
access-list nonat extended permit ip 10.0.1.0 255.255.255.0 10.0.2.0 255.255.255.0
access-list nonat extended permit ip 10.0.1.0 255.255.255.0 192.168.2.0 255.255.255.0
nat (dmz) 0 access-list nonat
Site B
access-list nonat extended permit ip 10.0.2.0 255.255.255.0 10.0.1.0 255.255.255.0
access-list nonat extended permit ip 10.0.2.0 255.255.255.0 192.168.1.0 255.255.255.0
workorderps Tue, 09/22/2009 - 06:29
thanks, I had forgotten to add the dmz's to the crypto acl.
Now works between dmzA and dmzB, but not between dmzB to localA, ie 10.0.2.20 -> 192.168.1.8 - says in packet inspector, (vpn) flow denied - I must have missed something haven't I?
cheers / Peter
acomiskey Tue, 09/22/2009 - 09:01
Post your config if you're still having issues.
Please rate helpful posts.
workorderps Tue, 09/22/2009 - 15:09
I managed to solve the vpn-pair problems, and the access from dmz-to inside, so traffic now flows properly between hosts not in any static translations. What remains to solve are traffic involving hosts in static translations, as that traffic does not get routed via the tunnel, but instead to the outside world. We have this to be able to have dns servers in both locations, that do report the correct external IP when you query any server either from inside or from outside our sites.
Here's a more complete listing with your included fix for the traffic between the nets, that I'm truly grateful for.
But how do we solve traffic between hosts in static translation over the tunnel?
cheers / Peter
object-group service DMZ_to_Inside
service-object icmp
service-object tcp-udp eq domain
service-object tcp eq 3389
service-object tcp-udp eq 389
service-object tcp range 2221 2222
service-object tcp-udp eq 636
service-object tcp eq 135
service-object tcp range 3268 3269
service-object udp eq 4500
service-object udp eq isakmp
service-object tcp eq 445
service-object tcp eq netbios-ssn
service-object udp eq netbios-dgm
service-object udp eq netbios-ns
service-object tcp-udp range 1024 1026
service-object tcp-udp eq 88
service-object udp eq ntp
service-object tcp-udp range 1433 1434
Site A
access-list extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list nonat extended permit ip any 10.0.0.0 255.0.0.0
access-list nonat extended permit ip any 192.168.0.0 255.255.0.0
access-list dmz_access_in extended permit object-group DMZ_to_Inside any 192.168.1.0 255.255.255.0
access-list dmz_access_in remark permit all traffic to less secure networks
access-list dmz_access_in extended permit ip any any
access-group dmz_access_in in interface dmz
static (outside,inside) 192.168.2.3 83.209.68.195 netmask 255.255.255.255 dns
Site B
access-list extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list dmz_access_in extended permit object-group DMZ_to_Inside any 192.168.2.0 255.255.255.0
static (inside,outside) 83.209.68.195 192.168.2.3 netmask 255.255.255.255 dns
acomiskey Wed, 09/23/2009 - 04:43
I think you're referring to something like this...
Site B
nat (inside) 0 access-list nonat_inside
access-list nonat_inside extended permit ip host 192.168.2.3 10.0.1.0 255.255.255.0
access-list nonat_inside extended permit ip host 192.168.2.3 192.168.1.0 255.255.255.0
workorderps Wed, 09/23/2009 - 05:29
No, that's already in place with the following ruleset:
access-list inside_nat0_outbound extended permit ip any 10.0.0.0 255.0.0.0
access-list inside_nat0_outbound extended permit ip any 192.168.0.0 255.255.0.0
nat (inside) 0 access-list inside_nat0_outbound
The entire problem lies with the
of Site B, as the UN-IP process already at the flow level stops to analyze the flow when it realises the translate of the other side is an external address, and it doesn't pair the static outside // actually local // address with the configured vpn-tunnel.
See the below packet trace, as communicating from 2.150 to 1.14 goes via the outside, but 2.150 to 1.8 takes the desired path over the vpn-tunnel. I think I can resolve this by skipping the dns translate rules, which is the only reason to keep the outside static on SiteB - but it makes it necessary to have a local domain, and another domain that is the public one. So - not the preferred way, but atleast an option. If you have a better suggestion I'm happy to try it.
The packet trace is within the attachment, as it just barely exceeds 4000 characters.
workorderps Thu, 09/24/2009 - 13:47
My sweet solution isn't at all sweet. By having two domains, one for the outside, and the other for the inside, all services that rely on the host header (ie web sites, certs etc) also has to be duplicated.
So to recap the problem, internal network, at two sites - interconnected via vpn, and dns-servers at both sites. How do we get the dns-rewrite feature to work inbound and outbound from both sites, so that all traffic regarding any internal site still is routed over the vpn-tunnel? - or is this an oversight in the design of the ASA/IOS route logic - and only solution is to go BGP4 all the way?
