09-22-2009 04:51 AM
Inventory fail for Switch 6509 on LMS 3.0.1.
hardwware: WS-C6513
ios: 12.2(18)SXF10a
We modified snmp timeout to 15s but the issue still exist.
Solved! Go to Solution.
09-23-2009 07:24 AM
The problem is an SNMP timeout. How did you increase the timeout value for this device?
09-22-2009 07:10 AM
Post the IC_Server.log.
09-22-2009 08:26 AM
09-22-2009 09:42 AM
What is the IP address of this switch?
09-23-2009 05:16 AM
ip@ is 152.33.250.10, we can see error message in IC_Server.log. But I don't know what does it mean.
09-23-2009 07:24 AM
09-23-2009 07:28 AM
Yes, I increase to 15s.
09-30-2009 06:36 AM
We had increase for the device on rme GUI the time as 15s, but it still failed.
So we increase to 20s. Now it works.
But, two 6509 (ios2.2(33)) devices fail, I believe taht we have encoured the bugid CSCsx58694.
Here you can find the error message on IC_server.log:
[ Tue Sep 29 14:34:51 CEST 2009 ],ERROR,[Thread-23],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,927, Exception occured in process method while processing: 152.33.150.10 ASA Error -193: Primary key for table 'PhysicalPort' is not unique
But, when reading CSCsx58694 doc, we can see that it is fixed in RME 4.3 that means in LMS 3.2.
Is it a way to correct with RME 4.1.1 ?
09-30-2009 07:07 AM
No, there is not a patch for RME 4.1.1.
