3560E Switches and 10G uplink ports
Sep 22nd, 2009
Thinking of 3560E switches with 2 X2 10G uplinks, I was wondering if I can use, at the same time, 1 uplink port @ 10G and the other one @ 1G, with the proper CVR-X2-SFP converter and SFP modules.
Thanks in advance!
Joseph W. Doherty Tue, 09/22/2009 - 07:25
Believe if you use a TwinGig converter in one of the module slots, you can connect one or two gig SFP links to it while the other module slot is 10 gig.
Leo Laohoo Tue, 09/22/2009 - 17:07
3560E-12D support TwinGig Adapter Converting 10 Gigabit Ethernet X2 Interface into Two Gigabit Ethernet SFP Interfaces.
