dhcp pool for vlan no native
Sep 22nd, 2009
I need to give ip addresses at an a Vlan (4) which isn't native on my switch and
not even management.
This command below are for native vlan.
How have to I modify it for another vlan configured on my switch ?
Can anybody advice me an a document about ?
Best regards
Lorenzo
interface vlan1
ip address 192.168.22.1 255.255.255.0
ip dhcp pool myvlan
network 192.168.22.128 255.255.255.128
dns-server 192.168.1.13 192.168.1.6
default-router 192.168.22.254
lease 10
MUHAMMAD SHAHEEN Tue, 09/22/2009 - 08:07
  • Silver, 250 points or more
Hi Lorenzo,
You need to add new configuration, the same way as you have for the existing IP range. For example
ip dhcp excuded-address 192.168.200.1
interface vlan4
ip address 192.168.200.1 255.255.255.0
ip dhcp pool NewVlan4
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
lease 10
Here I am assuming your new range will be 192.168.200.1/24 in VLAN4.
Hope this helps... please rate all helpfull posts.
Shaheen
lformelli Tue, 09/22/2009 - 08:20
Hi Shaheen ,
can I add this command
at my existing configuration ?
best regards
Lorenzo
Lucien Avramov Tue, 09/22/2009 - 08:32
  • Red, 2250 points or more
You can add as many networks statements as you want for DNS.
Basically the interface on a subnet A will provide DHCP as a DHCP server if there is a network statement for this subnet A under the DHCP pool.
