TACACS+ not working on WLC
jamaludeen_kc
Hi All,
I have configured tacacs for WLC. But I am not able to login to WLC using TACACS username and password.
Getting following message
Tue Sep 22 15:26:50 2009: Forwarding request to 10.0.0.1
6 port=49
Tue Sep 22 15:26:50 2009: tplus response: type=1 seq_no=2 session_id=ecf27238 le
ngth=6 encrypted=0
Tue Sep 22 15:26:50 2009: TPLUS_AUTHEN_STATUS = UNKNOWN(1)
Jamal.S
5 Replies 5
Lucien Avramov
Level 10
Level 10
Please turn on the WLC CLI:
debug aaa all enable
And post the output
Are you using ACS as a TACACS server?
Thanks for you reply...
Attached logs taken from Live WLC.
ACS IP's : 165.28.96.150,165.28.32.146.
Tacacs user ID : q03670
There is radius happening on the auth portion of the WLC.
There seems to be a misconfiguration issue.
What do the ACS failed logs say?
Can you make sure you followed exactly:
http://cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60sol.html#wpmkr1261119
Hi..
The problem is fixed now...Actaully there is a TACACS Key mismatch between ACS and WLC.
Thanks a lot for your wonderful support.
Great!
I guess we can mark this post resolved then.
