VPN help
Sep 22nd, 2009
Guys first of all this is my first post to security section as i am really new to security. Now i need a help and i am sure someone will help m eout.....we have a ASA 5505 device at customer which is connected to ADSL router for WAN access.....the ASA is connected to diferent devices. Now one of ouir partner company wants that they shd VPN to the firewall and then they are suppose to do remote managment for two networks (server networks) now guys i have never done that nor i have a idea how to do it can someone please tell me what i have to do there is no authentocation server so it has to be done on ASA itself.....what ar ethe steps i have to do....that the third party can VPN in to the firewall and then do remote managment for two networks...can someone plz tell me step by step....thanks guys i am hoping for an encouraging response.
Thanks again
Overall Rating: 5 (1 ratings)
The_guroo_2 Tue, 09/22/2009 - 17:35
Thanks for your help actually there is no ASDM installed in the ASA and customer is not ready to buy it from cisco so i had to do it with command line.....so can you please help me out secondly what is the way to check wheather ASDM is there or not.....thanks again
The_guroo_2 Wed, 09/23/2009 - 03:55
hi i did the show version now hoe do we connect to it....its https i know that and we have to enable http on firewall but what ip shd i put on my broswer and which interface do i connect my laptop....now i have a question like sdm is there any way it can be stored on laptop and connect to asa even if asa doesnt have one (ASDM)
When the ASDM is in flash and configured for use, you can connect to it and it will give you the option to install it as an application on your machine, the steps are:-
1) Configure the image
asdm image <>:/<>
2) Enable the http service
http server enable
3) Configure HTTP Access
http <> <> <>
4) Configure the HTTP authentication
aaa authentication http console LOCAL (This will allow local usernames to connect)
5) Create the user for ASDM access
username <> password <> privilege 15
