UNITY ver 6 Change Language
Afragoso2009
HI Team
Does any body now how can I change the language Cisco UNity from English to Portuguese ?
I see in my UNity just Englis! I need to have the portuguese suport as it my oficial language
Please Help
5 Replies 5
Jaime Valencia
There is no Unity 6, so please explain if this is CUC 6.X or if this is really Unity.
java
if this helps, please rate
java
Sorry
You right its CUC 6.0
There is also NO CUC 6.X
2.X or 7.X
Either way the procedure is the same as with CUCM, in downloads page choose the proper version and there will be a locale installer option, download the one you want. Install it via OS admin.
java
java
Hi Javalenc
Just to help me to clarify the name :
I have :
Cisco Unity Connection Ver 2.0.1.2000-337
Cisco Unified CM Ver 6.0.1.3000-7
Were can I found the Dowload page , in cisco site ? I must have a especial CCO to download it ?
www.cisco.com -> Support -> download SW.
To what you have access is defined by the CCO used.
java
java
