Issue with a Cisco 2821-HSEC/K9
Sep 22nd, 2009
Hello Folks!!
I have adquired a Cisco 2821 Security Bundle. I have conected a desktop computer with a straight-throught wire and I can see as the Lan Network fail intermittently. I have tested it with a cross-over wire and with other desktop and the problem is the same. The lan interface is disconnected and connected again intermittently.
Is possible that the interface GE0/0 is damaged.
Thanks in advance!!.
elias.manchon Tue, 09/22/2009 - 08:27
Hi, Thanks by your response. I can see that the SYS PWR led is blinking, then it stops for a moment and the led's light is switched on, then it switch off and it starts again the same process.
I think that the problem is the proper device and not the network.
Paolo Bevilacqua Tue, 09/22/2009 - 08:31
Have you connected to the router via serial console for initial configuration ?
If you have not done that, whatever the LAN port does, is irrelevant.
elias.manchon Tue, 09/22/2009 - 08:36
One moment...!, I have removed the Compact Flash and now it's working. The Compact Flash was inserted when I unpcked the product.
elias.manchon Tue, 09/22/2009 - 08:47
I have got to enter via serial. I can see the next error during the boot:
****** ERROR detected on PCI0 Bus
****** Try RESEATING all modules in the system
****** pci0_int_cause 0x00000200,
****** pci0_err_addr 0x00023801, pci0_err_cmd 0x0000000A
****** PCI Target Abort
Paolo Bevilacqua Tue, 09/22/2009 - 10:14
Do what it's suggesting you, open it and reseat all modules.
If still trouble, return to vendor.
