Load Balancing with BGP in Multihome Environment
Sep 22nd, 2009
Hello
I am attaching a diagram with a topology for implementing HSRP and BGP for doing a load balancing with BGP through two internet dedicated each one with its last mille independent.
Besides, i am enclosing the BGP configuration suggest of both routers (CPEs) installed on the LAN of the costumer.
The question is, how can i get doing load balancing for traffic inbound and outbound in this solution??
Giuseppe Larosa Tue, 09/22/2009 - 09:08
  • Hall of Fame,
    Founding Member
Hello Alexis,
using GLBP instead of HSRP can help if customer client vlans are directly attached to the routers.
But I see that there is a FW in between that is the next-hop of the customer IP subnets so even GLBP is not of help here.
You can use two HSRP groups and you can have R1 master of group1 and R2 master of group2.
the firewall may support two default static routes out its outside interface using as next-hops the two VIPs.
For example ASA supports it in release 7.x or newer.
Also if you prepend on secondary router traffic will come back from primary router.
To try to have some traffic to come back on secondary you should remove prepending.
Your current configuration provides redundancy but no load balancing.
Hope to help
Giuseppe
alemunmo81 Tue, 09/22/2009 - 13:34
Checking your message above, and being focus on the load balancing for the traffic outside, i have a doubt of the configuration that i could have on the LAN using two HSRP groups, because my intention is to use the same subnet 190.66.3.0/28 for having two master, can i do this??
I am enclosing the HSRP configurations as a proposal for your checking:
Router Ppal
interface FastEthernet0/0
description LAN-PPAL
ip address 190.66.3.4 255.255.255.248
load-interval 30
speed 100
full-duplex
standby 1 ip 190.66.3.2
standby 1 priority 130
standby 1 preempt
standby 1 track FastEthernet0/1.1 50
standby 1 track 100 decrement 50
standby 2 ip 190.66.3.6
standby 2 priority 110
standby 2 preempt
Router Backup
description LAN_BACKUP
ip address 190.66.3.3 255.255.255.248
load-interval 30
speed 100
full-duplex
standby 1 priority 110
standby 1 preempt
standby 2 priority 130
standby 2 preempt
standby 2 track FastEthernet0/1 50
standby 2 track 100 decrement 50
ASA 7.x
route outside 0.0.0.0 0.0.0.0 190.66.3.2
route outside 0.0.0.0 0.0.0.0 190.66.3.6
Giuseppe Larosa Tue, 09/22/2009 - 22:55
  • Hall of Fame,
    Founding Member
Hello Alexis,
this can be done and it is what I was suggesting: you can define multiple HSRP groups on the same IP subnet if :
they use different group number
they have a different VIP.
the subnet has to be big enough to accomodate the ip addresses of VIPs, router interfaces, ASA ip address.
And you have 6 addresses available in your subnet.
this is called MHSRP by someone.
Hope to help
Giuseppe
alemunmo81 Tue, 09/22/2009 - 14:03
Router Ppal
load-interval 30
speed 100
full-duplex
standby 1 preempt
standby 2 preempt
Router Backup
load-interval 30
speed 100
full-duplex
standby 1 preempt
standby 2 preempt
ASA 7.x
