802.1x debug not working
Sep 22nd, 2009
I'm trying to get 802.1x on a Cat6509-E to work with Microsoft IAS. I'm still working through the details, however when I issue 'debug dot1x all' and then issue a 'term mon' command, I never see any dot1x debug information.
DET1TR1E#sh deb
dot1x:
Dot1x registry info debugging is on
Dot1x redundancy info debugging is on
Dot1x packet info debugging is on
Dot1x events debugging is on
Dot1x State machine transitions and actions debugging is on
Dot1x Errors debugging is on
Here is the global dot1x config:
aaa authentication dot1x default group radius
aaa authorization network default group radius
dot1x system-auth-control
dot1x guest-vlan supplicant
here is the interface dot1x config:
dot1x pae authenticator
dot1x port-control auto
dot1x guest-vlan 900
dot1x auth-fail vlan 900
This used to work at one time. I have no idea why it doesn't show any transactions in the terminal window.
Any help is appreciated.
Shane
simontibbitts Tue, 09/22/2009 - 10:59
  • Silver, 250 points or more
Hi Shane.
I just thought I would check that debugging messages are allowed to be sent to the console? A 'show logging' will show whether debugs are allowed to the console or not.
A lot of the time engineers turn off console logging and log to buffer in order to lower the impact of debugging. Most of the time they forget to turn it back on afterwards!
Just wanted to check this wasn't the case.
Simon
s.clinard Wed, 10/07/2009 - 11:35
Hi Simon - this doesn't seem to be the case. I am SSH'd to the switch and verified that logging monitor is set to informational. This should send debugging and informational messages to the monitor session (in my case vty3).
Shane
