Dual SIP Trunks Same Provider
Sep 22nd, 2009
Can a single CUBE gateway support two separate SIP trunks to the same provider?
There will be two separate paths to reach the provider, one for each trunk. One routes via the LAN to the primary MPLS circuit, and one will use a T1 directly off of the CUBE gateway.
We're running UCM 7.1(2).
