UC520 second call handling
Answered Question
Sep 22nd, 2009
I have a UC520 configuration as follows.  PRI, Main number, (555-111-2222) is mapped to extension 222.  This is a shared line appearance on all phones (7960).  My problem is that the second call that comes in to that number rings busy, or voicemail, depending on how I set CFB.  I would like it to ring on the phones.  If possible I would like to do this strictly via CCA 2.1 or last resort CUE gui.
Correct Answer by Saurabh Verma about 7 years 5 months ago
One way to do this in CCA 2.1 would be to create multiple shared directory numbers - 222, 223 and set the call-forward no-answer and call-forward busy target on 222 to 223. Also, you will need to make sure that both 222 and 223 are configured as overlays on IP Phones.
HTH,
Saurabh
Overall Rating: 5 (1 ratings)
Correct Answer
Saurabh Verma Tue, 09/22/2009 - 11:01
HTH,
Saurabh
chris unger Fri, 10/16/2009 - 05:38
this has been resolved.  Once I went to the CLI, i noticed that there was a huntstop, which was causing the issue.
Related Content
