NTP Authentication
I am having trouble getting my NTP to authenticate i can get it to sync with the ntp authenticate command out of the router 2 config and then enter it back in and it continues to sync but i am not sure if it is actually using the authentication at that point. here are the configs:
ROuter1 (Master):
ntp authentication-key 10 md5 Mysecret
ntp authenticate
ntp trusted-key 10
ntp server 192.192.192.192 source FastEthernet0/0
end
Router2:
ntp authenticate
ntp server 10.0.0.0 key 10
end
