What does it means??
Answered Question
Sep 22nd, 2009
What's System Memory Summary means, with all the values that it conteins in a CVPN3030?? Thanks.
Regards.
Elias Vucinovich.
Correct Answer by slmansfield about 7 years 10 months ago
Sorry I don't know why that value is zero, but I can tell you that it's zero on my VPN concentrators and they've been running fine for many years.
Please consider rating my response if it was helpful to you.
Overall Rating: 5 (1 ratings)
slmansfield Tue, 09/22/2009 - 12:10
  • Silver, 250 points or more
Here is a URL that explains the information under "System Status" on the VPN 3000 concentrator.
The System Memory Summary shows how much memory is installed on the concentrator, whether there is sufficient memory for normal operation of the concentrator, and a breakdown of memory usage in memory blocks.
http://www.cisco.com/en/US/docs/security/vpn3000/vpn3000_47/administration/guide/sysstat.html
evucinovich Tue, 09/22/2009 - 12:22
Ohh, this is a great link, i will download all the book.
But i have a doubt. The blocks >8192 i have 0 bloks free, like the document. Is this good or it is sayng that samething wrong is hapen to it??
Thanks a lot!!!!!!
Correct Answer
slmansfield Tue, 09/22/2009 - 12:36
