CUCM LDAP sync and default group membership?
Sep 22nd, 2009
  • Bronze, 100 points or more
Is it (still) the case that there is no facility for automatically associating new incoming LDAP users from the DirSync process with a default set of permissions (user groups, i.e. Standard CCM End User) on CUCM?
Jaime Valencia Tue, 09/22/2009 - 20:32
  • Cisco Employee,
  • Hall of Fame,
    2011
Sadly that's still something you need to do manually after the LDAP sync
java
if this helps, please rate
Keith Fulcher Fri, 11/27/2009 - 02:44
I take that this is still a fact, because I can not see where to configure it in a 7.13a
