Changing lan ip address on the uc520
Answered Question
Sep 22nd, 2009
When i setup the router, i assigned it the default ip of
However, i would like to change it to How can i do this in the CCA or cli(specific steps please) ?
Can i change it under Routing-DHCP Server- and under DHCP Pools, modify the data vlan1 network, start and end ip addresses and default router?
Or is it to be changed elsewhere ?
Correct Answer by Marcos Hernandez about 7 years 1 month ago
Delete and recreate NAT at the end.
Murtaza, please refer to this thread:
Notice that you will also have to delete the NAT service and then recreate it. Do not do this over the WAN or through VPN. Connect locally.
Overall Rating: 5 (2 ratings)
murtazashikarii Wed, 09/23/2009 - 08:26
in step 3, while changing the settings on the smartport, do i need to change it for all smartports except for the one i am connected to ?, example, if i am connected to 1/7, i should do it for all the rest?
And then in step7, i can connect to any other switch port (which was already configured in step 3) to open the CCA using the new vlan ip?
Marcos Hernandez Wed, 09/23/2009 - 08:33
Yes to both questions. Good catch. Make sure you configure the port you were on only after you have connected your computer to the new VLAN.
Also, and I can't stress this enough, do not forget about deleting and recreating the NAT settings and the firewall config.
murtazashikarii Wed, 09/23/2009 - 08:37
Do i need to delete the NAT settings first or perform the NAT config in step 5 first? i am a little lost here.
murtazashikarii Wed, 09/23/2009 - 08:35
Also, there is a step for adding the NAT. Do i need to do anything over and above that step wrt NAT?
Related Content
