Logging, buffer size and show version
Sep 22nd, 2009
I would like to know on configuring the logging buffer for a 3750 stack. Is there any reference document? Also guess this is the DRAM of the switch so does it affect the data traffic?
When we issue the show version command we see "118784K/12280K bytes of memory", what is the first and second parameter here and is it related to the logging buffer configuration.
Thx in advance.
Amol More.
Overall Rating: 3 (2 ratings)
Giuseppe Larosa Tue, 09/22/2009 - 22:50
  • Hall of Fame,
    Founding Member
Hello Amol,
first parameter is main memory and second parameter is I/O memory used to process packets and frames.
you can check memory usage with
sh proc mem | inc Free
you should be able to set the logging buffer to 1000000 bytes with no issues.
This can help in troubleshooting issues.
Hope to help
Giuseppe
rush2amol Tue, 09/22/2009 - 23:15
Hey, i am a bit confused. I was checking a document "http://www.fredshack.com/docs/cisco_ios_basics.html" on web which says the show version gives you the packet mem and process mem allocation details like routing protocol etc.
Further I checked another switch for its show version "cisco WS-C3750E-24TD (PowerPC405) processor (revision E0) with 0K/16376K bytes of memory". I am not sure if first parameter is main memory.
Amol M.
iyde Wed, 09/23/2009 - 11:55
  • Silver, 250 points or more
This switch is running an IOS version which has a bug, because as stated by Giuseppe the syntax is processor or main memory before the / and I/O or packet memory after the /
Obviously a switch cannot run without any processor memory.
If you do a full "show proc mem" you will get information about what amount of memory is used for which processes etc.
rush2amol Wed, 09/23/2009 - 21:33
ok. I hope this bug does not hamper any of our production traffic ?
Thx both for your responses.
Amol More.
