Disable Pulse Dialing on FXS port
Sep 23rd, 2009
Hello
A customer is having problems with analog phone that are connected to FXS ports on a VG224 (SCCP). The phone is dialing using DTMF. Unfortunately after gonig off-hook the phone sends a pulse dialed "1" to the VG224 (see attached log). Is there a command to disable pulse dialing completely on the VG224 or is it possible configure a delay so that (pulse dialed) digits in the first 500ms will be ignored?
Any input is welcome and many thanks in advance
Kind Regards
Stefan Christen
paolo bevilacqua Wed, 09/23/2009 - 04:21
  • Hall of Fame,
    Founding Member
I don't think it's possible to do that.
