ccm 4.1(3)5srd + Bios not detected
Sep 23rd, 2009
hello,
wa had a serious electrical problem in the bilding. all server are rebooted, but the CCM cloudnt continue the boot sequences ( wa have an error message : the bios not detected).
please can someone help me what i can do?
thanks
hicham
Adam Thompson Thu, 09/24/2009 - 10:36
  • Silver, 250 points or more
Well at first glance, it sounds like you may have a dead motherboard. It is possible that your electrical problems fried it.
Another issue could be the BIOS battery. You could try replacing this battery and see what happens. This would be the easy option.
If your motherboard is toast, I would open a TAC RMA case to see if you can get a replacement.
Adam
Please rate if helpful
