ACS 5.0 with PEAP
Answered Question
Sep 23rd, 2009
Hi there
i saw the following table about authentication protocols in ACS 5.0:
PEAP (with EAP-MSCHAPv2 inner method) Yes
PEAP (with EAP-GTC inner method) No
PEAP (with EAP-TLS inner method) No
EAP-FAST (with EAP-MSCHAPv2 inner method) Yes
EAP-FAST (with EAP-GTC inner method) No
EAP-FAST (with EAP-TLS inner method) No
In my opinion this should work for every Microsoft windows clients, right? Are there any clients today which still use EAP-GTC or EAP-TLS?
Thanks in advance and best regards.
Dominic
Correct Answer by Jatin Katyal about 7 years 7 months ago
Hi Dominic,
EAP-GTC is Cisco propritary, so its meant to work with Cisco products only. But, I also saw that we've an option for EAP-GTC on IBM utility.
In order to enable EAp_GTC, you can use either one of them:
Cisco350card
Cisco ACU utility
AS far as EAP-TLS is concerned, It will work with all Microsoft clients as EAP-TLS protocol is an IETF open standard.
EAP-TLS is supported by the following operating systems (natively):
* Mac OS X 10.3 (and above),
* Windows 2000 SP4
* Windows XP
* Windows Vista
* Windows Server 2003
* Windows Mobile 2003 (and above)
* Windows CE 4.2
JK
Overall Rating: 5 (1 ratings)
Correct Answer
Jatin Katyal Thu, 09/24/2009 - 06:59
  • Cisco Employee,
Hi Dominic,
Cisco350card
Cisco ACU utility
* Windows 2000 SP4
* Windows XP
* Windows Vista
* Windows CE 4.2
JK
