OID Checking on Device
Sep 23rd, 2009
WHat is the difference of both the errors in 3rd Party ( Open view Server)
snmpwalk: No response arrived before timeout.
# snmpwalk 10.194.209.252 1.3.6.1.4.1.9.7.101
no MIB objects contained under subtree.
Overall Rating: 1 (1 ratings)
yjdabear Wed, 09/23/2009 - 05:55
  • Gold, 750 points or more
"No response" could be due to a variety of reasons: 1) Wrong SNMP credentials sent by the SNMP client (HPOV in this case). 2) Restrictions (e.g. ACL) on SNMP traffic anywhere along the way from the SNMP host itself to the last hop in front of HPOV. 3) SNMP host is really down.
"[No] MIB objects contained..." usually means that particular MIB is not supported by that particular SNMP host. There might be other reasons, but I can't think of any right now.
cisco-blue Thu, 09/24/2009 - 03:35
i m getting the error like below, what can be the reason
# snmpwalk hostname 1.3.6.1.2.1.17
dot1dBridge.dot1dBase.dot1dBaseBridgeAddress.0 : OCTET STRING- (hex): length =
6
0: 00 1c f6 c1 c4 c0 -- -- -- -- -- -- -- -- -- -- ................
dot1dBridge.dot1dBase.dot1dBaseNumPorts.0 : INTEGER: 0
dot1dBridge.dot1dBase.dot1dBaseType.0 : INTEGER: transparent-only
dot1dBridge.dot1dStp.dot1dStpProtocolSpecification.0 : INTEGER: unknown
dot1dBridge.dot1dStp.dot1dStpPriority.0 : INTEGER: 32768
dot1dBridge.dot1dStp.dot1dStpTimeSinceTopologyChange.0 : Timeticks: (0) 0:00:00.
00
dot1dBridge.dot1dStp.dot1dStpTopChanges.0 : Counter: 0
dot1dBridge.dot1dStp.dot1dStpDesignatedRoot.0 : OCTET STRING- (hex): length =
8
0: 00 00 00 00 00 00 00 00 -- -- -- -- -- -- -- -- ................
dot1dBridge.dot1dStp.dot1dStpRootCost.0 : INTEGER: 0
dot1dBridge.dot1dStp.dot1dStpRootPort.0 : INTEGER: 0
dot1dBridge.dot1dStp.dot1dStpMaxAge.0 : INTEGER: 0
dot1dBridge.dot1dStp.dot1dStpHelloTime.0 : INTEGER: 0
dot1dBridge.dot1dStp.dot1dStpHoldTime.0 : INTEGER: 0
dot1dBridge.dot1dStp.dot1dStpForwardDelay.0 : INTEGER: 0
dot1dBridge.dot1dStp.dot1dStpBridgeMaxAge.0 : INTEGER: 2000
dot1dBridge.dot1dStp.dot1dStpBridgeHelloTime.0 : INTEGER: 200
dot1dBridge.dot1dStp.dot1dStpBridgeForwardDelay.0 : INTEGER: 1500
dot1dBridge.dot1dTp.dot1dTpLearnedEntryDiscards.0 : Counter: 0
dot1dBridge.dot1dTp.dot1dTpAgingTime.0 : INTEGER: 300
