BGP in firewall/ASA
Sep 23rd, 2009
HI,
I have a client who is going for a new Firewall. However he seems to have got some positive points on having BGP in his PIX/ASA from some website. From my information his is going to be an intranet with just one gateway to the internet.
dies he really need a firewall with BGP.
What are the advantages if he goes for a Firewall with BGP
Rgds
Rajesh
naveen_b81 Thu, 09/24/2009 - 01:21
It all depends on his requirements. If there is just one path without any redundant paths requiring convergence, I wouldn't suggest BGP.It is as simple like a firewall is not meant for routing. There are a lot of Bug's and limitation by using BGP or infact routing on Cisco PIX/ASA.
I think that your client might have confused with the situation where BGP is run between two routers through a firewall - which means running BGP betwen two routers on different sides of the firewall.
