Shutdown problems mcs 7800
soporte-alh
we have a problem with mcs 7800.It's a windows 2000 5.00.2195 SP4 with call manager 4.2.
Is imposible restart or shutdown this machine without push the init bottom.
symptoms:
Windows close applications, lost ping and lost image signal but the server fails to shut down until you physically click the button.
any suggestion?
Jaime Valencia
If the server has ILO try that way, otherwise i don't see any other option that does not involve pushing the button on the server
java
if this helps, please rate
java
we hanven't ILO
