NAT static and connections outside-to-inside
Sep 23rd, 2009
we have configured static NAT in our internet router. Now the CPU has intervals with 100%. We have seen that is due to NAT entries number. Besides the entries are created by external host that try to connect to Global/public ip address. Is there any way that configure NAT to avoid connections outside-to-inside?. I suppose
that an ACL use established FLAG could help me but I want to know if there is a NAT option to do it.
Laurent Aubert Wed, 09/23/2009 - 10:40
What is your configuration ? what does the nat table look like ?
Laurent.
tonio.ojea Thu, 09/24/2009 - 02:02
You could use an access list in your wan interface denying incoming tcp connections with the syn bit active, like this
int FaX/X
desc WAN
ip access-group 135 in
ip nat outside
access-list 135 deny tcp any (publicIp) (public network) syn
access-list 135 permit any any
