cpu @ 99%
Answered Question
Sep 23rd, 2009
I have a 4510 that I recently put into production and its cpu is pegged at 99 constantly. A show proc cpu sort shows
Cat4k Mgmt LoPri to be the main culprit. A sh platform health reveals 2 processes that looked to be associated:
K5L3Unicast Adj Tabl 2.00 31.49 15 11 100 500 31 33 33 3822:10
K5 L2 Hardware Addre 2.00 59.05 20 14 100 500 71 56 50 5837:19
HBG-DataCenter-4510R(config)#do sh proc cpu sorted
CPU utilization for five seconds: 99%/0%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
54 620006660 52990203 11700 89.28% 89.03% 88.48% 0 Cat4k Mgmt LoPri
53 61832668 111544261 554 8.95% 8.90% 9.13% 0 Cat4k Mgmt HiPri
120 2164724 5933214 364 0.23% 0.31% 0.31% 0 Spanning Tree
38 2478104 863775 2868 0.23% 0.25% 0.23% 0 IDB Work
114 904608 2828492 319 0.15% 0.13% 0.13% 0 IP Input
107 743744 2327469 319 0.15% 0.12% 0.08% 0 CDP Protocol
163 2880 1455 1979 0.07% 0.10% 0.41% 1 SSH Process
14 982968 4783695 205 0.07% 0.11% 0.11% 0 ARP Input
183 107260 1481823 72 0.07% 0.01% 0.00% 0 VLAN Manager
62 173040 282995 611 0.07% 0.02% 0.00% 0 Compute load avg
182 336500 18595895 18 0.07% 0.05% 0.07% 0 PM Callback
155 178620 5754473 31 0.07% 0.03% 0.02% 0 CEF: IPv4 proces
13 0 10 0 0.00% 0.00% 0.00% 0 ifIndex Receive
12 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
15 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API
11 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
10 96 5 19200 0.00% 0.00% 0.00% 0 PrstVbl
9 0 2 0 0.00% 0.00% 0.00% 0 Timers
8 0 181 0 0.00% 0.00% 0.00% 0 Pool Manager
20 4 397 10 0.00% 0.00% 0.00% 0 EEM ED Syslog
16 4 10 400 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
sh platform cpu pack stat all
Packets Dropped In Processing by CPU event
Event Total 5 sec avg 1 min avg 5 min avg 1 hour avg
Unknown 0 0 0 0 0
Sa Miss 203154944 418 482 1648 953
Any ideas why this?
thank you,
Bill
Correct Answer by glen.grant about 7 years 6 months ago
Take a look at this page and see if this helps with troubleshooting , if not a TAC case may need to be opened.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
Overall Rating: 4.8 (3 ratings)
WILLIAM STEGMAN Wed, 09/23/2009 - 09:41
I found an oracle listener client using the command below. It's interfaces are bonded and somehow messing up the switch's cpu.
Switch#debug platform packet all receive buffer
platform packet debugging is on
Switch#show platform cpu packet buffered
Total Received Packets Buffered: 36
thank you Glen
WILLIAM STEGMAN Wed, 09/23/2009 - 08:54
I don't think it's a bug, I'm running Version 12.2(53)SG. Do you know what these processes might be associated with?
I am running EIGRP with a couple distribution switches as neighbors.
Lucien Avramov Wed, 09/23/2009 - 09:28
  • Red, 2250 points or more
Ok now that I know your version, you are not impacted by this.
The process which has consumed the highest CPU util. was "K5 L2 Hardware Addre" and "K5L3Unicast Adj Tabl".
Process "K5 L2 Hardware Addre" is active, when new MAC addresses are learned and subsequently adjacency table has to be rewritten as well, hence "K5L3Unicast Adj Tabl" is active.
If a packet is received with an unknown source MAC address, a copy of that packet is forwarded to the CPU for MAC address learning. This is also happening, when a packet with an already known source MAC address is received on another interface. A copy is sent to the CPU and this MAC is re-learned on another interface.
In the phase of high CPU utilization, it could be observed that the traffic has been continuously received between a port channel and a gig interface for example.
I hope this clears out your questions.
boumendil Wed, 06/23/2010 - 08:19
Hi Lucien,
You mention that "In the phase of high CPU utilization, it could be observed that the traffic has been continuously received between a port channel and a gig interface for example.". Do you mean this is a known bug or a platform limitation.
I experience the same on multiple 4900M (either L2/L3 or pure L2 switch).
Thank you.
regards,
SB
