AAA Accounting on Routers
Answered Question
Sep 23rd, 2009
Hey guys,
I am looking for some help in setting up my router to where it reports to my CSACS all commands executed by users. For example, I login as the user bbaggins and I make changes to an ACL configuration, is there a way for the commands I typed in to be logged by the ACS?
Thanks for your help.
Correct Answer by Jagdeep Gambhir about 7 years 9 months ago
You need to set up tacacs for that. Here are the commands.
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
Command accounting logs are stored in tacacs administration logs. Also there is a known issue on ver 4.1.1 and we need to apply patch ACS 4.1.1.23.5 to fix the issue.
Patch for appliance is available on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
Patch name : ACS SE 4.1.1.23.5 accumulative patch
Patch for acs windows is available on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des
Patch Name : ACS 4.1.1.23.5 accumulative patch
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Wed, 09/23/2009 - 07:42
  • Red, 2250 points or more
~JG
Joshua Engels Wed, 09/23/2009 - 07:46
You are the man. I had it setup and didn't realize it was under Administration. Thanks so much for your help.
Joshua Engels Wed, 09/23/2009 - 07:49
One last question.....
do I need "aaa accounting commands 1 default start-stop group tacacs+" and "aaa accounting commands 15 default start-stop group tacacs"? What for?
Jagdeep Gambhir Wed, 09/23/2009 - 08:14
That is to log accounting for Priv 1 command
That is to log accounting for Priv 15 command
~JG
