false archive failed report on RME 4.3
Sep 23rd, 2009
devices already deleted on DCR still reported as "archive failed" when I search the device, can't be found neither on RME nor on CM. how I can get rid of this false information from RME?
Joe Clarke Wed, 09/23/2009 - 10:18
Check the Common Services > Device and Credentials > Reports > Devices not configured in ACS report to see if the missing devices are listed there.
Joe Clarke Wed, 09/23/2009 - 10:28
Then you need to either re-add them to ACS, or temporarily break ACS, then remove the devices from DCR. Once DCR is clean, you can re-enable ACS integration.
