syslog id 106100 is no longer?
Sep 23rd, 2009
I just recently upgraded to version 8.2 on our ASA's and can no longer see the syslog id of 106100.
When checking under "syslog setup" the entry is there but has the logging level as N/A and will not allow me to change it.
Any one else or how do I fix this? I have many scripts that parse this syslog data that is no longer working.
campbech1 Wed, 09/23/2009 - 11:37
Yes, I have "log" checked on the ACL along with the logging level to "warnings".
Before the upgrade to 8.2 this was working great.
I found this link where another person was also complaining about it, will try their workaround.
http://www.showcrypto.com/
campbech1 Mon, 09/28/2009 - 11:49
I think the problem is that I use to be able to reclassify the 106100 syslog id as a warning and not as the default informational. No way to do that now.
