ICM 7.2.3 - ID Entered not found
Sep 23rd, 2009
After changing a working agent ID in ICM from 57019 to 67504, user got error, "The ID you entered was not found". We deleted agent from ICM but agent still shows in Desktop Admin even after 30 min wait.
Overall Rating: 3.7 (3 ratings)
david.macias Wed, 09/23/2009 - 14:46
  • Blue, 1500 points or more
Did you check the deleted items and purge that?
david
The CAD LDAP synchronizes with the ICM database every 10 mins. You should not have to wait 30 mins. Can you check the logs of the sync service to ensure it is synchronizing.
Can you try a Manual Sync from the Desktop Admin (I don't like to do this when a lot of agents are logged in, so maybe towards the end of the day).
Geoff
susanmcpherson Thu, 09/24/2009 - 06:03
I saw that the CAD LDAP synchronizes with the ICM database every 10 mins so that is why I waited 30. Can you point me in the right direction on how to check the logs of the sync service? P.S. This is a new day and the login ID works now but I would still like to check the logs. Thanks much.
david.macias Thu, 09/24/2009 - 07:06
Check the Cisco CAD Service Information document for your version. It has a section on troubleshooting sync services.
david
