Port forwading on ASA5520/8.21
Sep 23rd, 2009
I have setup NAT/PAT on ASA5520 and it 's working properly. Right now, I have one webserver resides on inside network and I want to forward 2 different IP addresses to this inside server by the same port, like below
Outside IP address1:80 -> Inside IP address:80
Outside IP address2:80 -> Inside IP address:80
But ASA doesn't allow me to do that, it prompts "ERROR: duplicate of existing static".
Can anyone advise how to achieve it? TIA!
Overall Rating: 4.5 (2 ratings)
David Lin Wed, 09/23/2009 - 11:49
Jorge, thanks a lot.
The link instructs how to translate multiple IP addressed to a single IP addres. It works fine.
But is there any way to do the port translation like I mentioned above?
I trid below command but it didn't go.
static (inside,outside) tcp 172.16.1.10 8080 access-list Test ?
configure mode commands/options:
<0-65535> The maximum number of simultaneous tcp connections the local IP
hosts are to allow, default is 0 which means unlimited
connections. Idle connections are closed after the time
specified by the timeout conn command
dns Use the created xlate to rewrite DNS address record
netmask Configure Netmask to apply to IP addresses
norandomseq Disable TCP sequence number randomization
tcp Configure TCP specific parameters
udp Configure UDP specific parameters
Certainly, I can set up the ACE to block other ports on that IP address translation instead.
Thank you.
JORGE RODRIGUEZ Wed, 09/23/2009 - 12:04
  • Green, 3000 points or more
say local IP 10.10.10.10 - and public IPs 20.20.20.20, 20.20.20.30
access-list policy1 permit tcp host 10.10.10.10 eq 80 any
access-list policy2 permit tcp host 10.10.10.10 eq 80 any
static (inside,outside) tcp 20.20.20.20 8080 access-list policy1
static (inside,outside) tcp 20.20.20.30 8080 access-list policy2
Is this what you're trying to do?
[edit]
made couple of corrections - probably need to lab this one , but try it.
