Anyconnect Client & Clean Access SSO
Answered Question
Sep 23rd, 2009
I have a ASA 5550 setup with the AnyConnect Essentials License and it works. Behind the VPN we have a CA server running 4.1.8 using SSO. The VPN aspect of this works but I've run into a issue with OSX and the CA Agent. Windows and the CA Agent SSO works. When you connect to the VPN via AnyConnect on a MAC (OSX 10.5.8) it connects but when the CA Agent starts communicating with the CAS you are disconnected.
I've looked the traffic between the ASA and CAS, the Radius traffic looks good. Is this a bug?
ASA: 8.2(1)
CAS/CAM: 4.1.8
MAC CA Agent: 4.5.0 (it is supported per docs).
-Dusty
Correct Answer by tprendergast about 7 years 5 months ago
Hi Dusty,
Try this:
- Look in your appropriate user directory for the CCAAgent dir (in my case it was: /Users/tprender/Library/Application Support/Cisco Systems/CCAAgent)
- Create a preference.plist file if it doesn't already exist -- if it does exist , just add the key/value strings for "VlanDetectInterval" below
- To create the file, do "vi preference.plist" and enter this data:
<?xml version="1.0" encoding="UTF-8"?> http://www.apple.com/DTDs/ PropertyList-1.0.dtd">
AutoPopup
yes
VlanDetectInterval
- Save this file (in vi, :wq and ) and restart the Cisco NAC Agent (right click the icon and exit, then relaunch from your Applications menu)
The VlanDetectInterval must be set to 0 (default is 5) as Macintoshes do stupid things with the vpn interface.
I hope this helps. Please rate if you find this a valid solution.
Cheers,
Tim
Overall Rating: 5 (1 ratings)
Correct Answer
tprendergast Thu, 09/24/2009 - 09:19
Hi Dusty,
Try this:
AutoPopup
yes
VlanDetectInterval
Cheers,
Tim
draper7 Thu, 09/24/2009 - 10:14
Hey Tim,
Thanks for the help, it worked! The plist file already existed and had 5 like you said. Once I changed that and restarted CAA it worked. Not sure how we are going to get end users to do this though...
-Dusty
tprendergast Thu, 09/24/2009 - 10:26
Hey Dusty,
I published a document to all of my users on a wiki and via email. It is about as good as it gets. :)
Glad it helped!
