Max people in a barged shared line
Sep 23rd, 2009
CCM 4.1.3
I have a shared line setup with 10 phones and we would like all of them to be on the same call. when the 3rd person tries to enter a call, it says "exceeded barging capabilities".
Is there a max number of phones that can be on the same barged shared line.
thanks in adv,
:JoeL
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 09/23/2009 - 12:32
Using phone bridge max 3, using CFB depending of bridge capabilities and config
java
if this helps, please rate
joel@citadel Wed, 09/23/2009 - 12:35
thanks java,
I have "built in bridge" turned on....then I'm using the phone bridge right?
to use CFB do I need to use cbarge or do I need to disable "built-in bridge"
Jaime Valencia Wed, 09/23/2009 - 12:42
If you're using just barge and built-in bridge, yes, then only 3 users max.
You need to configure a valid MRGL for the phones that contains a CFB and use cBarge to use a CFB that supports more users.
Table 1-2 Barge with Shared Conference Bridge (cBarge) Configuration Checklist
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fsbarge.html#wp1098676
java
joel@citadel Thu, 09/24/2009 - 11:03
I use CCM 4.1.3, does this version have Single button Barge/cBarge?
I don't even see this option in my lab CCM 7.0 server...
pls help,
:JoeL
joel@citadel Thu, 09/24/2009 - 11:34
that was not the question....
if you look at the version 7 and 4.1.3 Feature guide, in the 7 it has a Single button Barge/cBarge...that was the question.
Jaime Valencia Thu, 09/24/2009 - 11:47
If it's not in the guide then the answer is obviously NO, otherwise config instructions would be there.
java
joel@citadel Thu, 09/24/2009 - 11:57
sure i do get that it's obvious,
but like i said in the second part, I don't even see this in my CCM 7.0 server?
