Issue Validating UCCX to CME
Sep 23rd, 2009
I am having an issue where I am getting and xml parse error when I try to Validate UCCX to CME.
I am using exactly the same config I have for a previous install.
The error I am getting is java.lang.RuntimeException: unable to parse XML response.
Is it more than likely the server install didnt work properly or an issue with the router ?
I have found if I create the outbound trigger it creates the config it needs but it will still not validate or accept calls.
At a bit of a loss as to what to do. I am currently reinstalling the server due to it only being a new install.
The UCCX ver is 7.01 the CME ver is 7.0
John
