Logging VPN connection information
Sep 23rd, 2009
I want to log to my syslog server the IP that a VPN client receives from the locally configured pool on my ASA for both IPSec and SSL VPN connections. Does anyone know the logging configuration I need to capture this information?
JORGE RODRIGUEZ Fri, 09/25/2009 - 09:53
  • Green, 3000 points or more
If you load your ASA ASDM look at realtime log.. have a user vpn in and watch the log you will see IDs and its severity category..
6Sep 25 2009 12:43:24 713228 Group = ciscovpn_ra_access, Username = XXX, IP = xxx.xxx.xxx.xx, Assigned private IP address 10.20.20.20 to remote user
That particular syslog message is ID :713228 , under severity 6 - informational.
for confirming the syslog ID go to syslog IDs link and look at the ID number .
http://www.cisco.com/en/US/docs/security/asa/asa82/system/message/logmsgs.html#wp5391006
for SSL VPN do the procedure above ..
for logging particualr IDs to syslog server use syslog filters.
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/monitor_syslog.html#wp1097397
