subinterfaces on 4948
Sep 23rd, 2009
  • Bronze, 100 points or more
EDIT: Just confirmed on the forum that sub-interfaces are not possible on 4948.
My stupid mistake, I didn't use the search feature earlier.
Thanks to original contributors.
Cheers
Guys,
Is it possible to configure L3 sub interfaces on 4948 switches (switches :-)
I don't have it with me hence can't verify.
Cheers
~sultan
Giuseppe Larosa Thu, 09/24/2009 - 04:42
  • Hall of Fame,
    Founding Member
Hello Sultan,
no problem you are wellcome.
I'm answering to your thread just to remove it from the list of unanswered.
Best Regards
Giuseppe
