Joe Clarke Thu, 09/24/2009 - 21:32
There is a problem with the archive on disk. Assuming that you have properly configured the archive under RME > Admin > Config Mgmt > Archive Settings, then try removing one of the problem devices from RME, then re-add it. See if the config can be successfully archived then.
vaibhav-g Thu, 09/24/2009 - 23:15
Hi Clark
I have done the same,it is working i have deleted one of the device and afer adding Archive is happening but i have so many devices.how we can solve this issue manually doing will take so much time.Kindly suggest
Vaibhav
Joe Clarke Fri, 09/25/2009 - 07:44
You will need to do it for all of the failing devices, or you will need to reinitialize the RME database:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=rmeng dmprefix=RME
