ASDM Read-Only access configuration in ACS 4.2
Sep 24th, 2009
Is that possible to configure read-only access of ASA firewall in ACS 4.2; that too particularly for ASDM?
Read-only is working fine for SSH protocol. But the customer requests for read-only access through ASDM.
Plz suggest a solution with detailed steps.
Many thanks!!
-Jags.
jagadeeshan.s Thu, 09/24/2009 - 02:03
Hi BR,
Our configuration is exactly similar like explained in the provided link. It works fine for SSH protocol (managing ASA firewall) but doesnt works with ASDM.
It keeps on asking the username & password.
-Jags.
Bela Mareczky Thu, 09/24/2009 - 03:17
Hi!
The ASDM cannot access the ASA using the required commands, so I think, the Cisco ACS command authorization rules are misconfigured.
Please check that, the Cisco ACS permits the following commands:
show version
show curpriv
perfmon interval 10
show asdm sessions
show firewall
show mode
show running-config aaa authorization
show running-config
show running-config
show running-config route
show running-config interface
show resource rule
show blocks
show curpriv
show vlan
show curpriv
show access-list brief
show access-list
Check that, the ASA AAA configuration contains "aaa authorization command [aaa server name] LOCAL" config.
You don't need to allow enable and shell exec privilege for this restricted ACS group.
Hope this helps!
Belabacsi
Jatin Katyal Thu, 09/24/2009 - 04:32
  • Cisco Employee,
Hi Jags,
I did recreate the same scenario few weeks back in my lab and this is what I found.
Following are minimum commands that need to be permitted for a read only
account for ASA 8.0(4) and ASDM 6.1.x
On the ASA
aaa authorization command TACACS+ LOCAL
aaa accounting command TACACS+ (optional)
On the ACS
Go to shared profile component >> shell command authorization set > add new > for read only access.
Check the radio button to deny all.
Command ---- Argument
copy ---- Permit all unmatched arguments
dir ---- Permit disk0:/dap.xml
enable ---- Permit
Perfmon ---- Permit interval 10
show ---- Permit all unmatched arguments
write ---- Permit net
Now go to the group
Jump to tacacs+ settings
Shell(exec)......priv level 15
enable access.....priv level 15
and apply the shell set.
ACS Shell Command Authorization Sets on IOS and ASA/PIX/FWSM Configuration Example
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a
00808d9138.shtml
JK
