ACE Module - Unable to view Memory Utilization (HUM)
Sep 24th, 2009
hi,
I am unable to view Memory Utilization of ACE Module via HUM.
And when I try to select it via 'Graph It', it says no instance available.
Is it supported by HUM.
Joe Clarke Thu, 09/24/2009 - 07:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is most likely bug CSCtb68766. If the ACE module does not support the cpmCPUTotal5MinRev object, then getting CPU utilization will fail. There is no workaround.
tech_trac Thu, 09/24/2009 - 10:43
The bug details are not stated in the Bug Toolkit.
Secondly, I had mentioned the issue with Memory and not CPU. CPU values can be seen via HUM without any problem.
Joe Clarke Thu, 09/24/2009 - 11:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
sorry, the problem is slightly different. The ACE does not support the CISCO-MEMORY-POOL-MIB nor the HOST-RESOURCE-MIB. Eithout either of these two MIBs, you will not be able to create a poller for memory on ACE modules using the built-in template.
However, the version of the CISCO-PROCESS-MIB supported by the ACE may have some memory objects. Post an SNMP Walk of 1.3.6.1.4.1.9.9.109.
Joe Clarke Sun, 09/27/2009 - 10:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Unfortunately, the CPM supported by the ACE doesn't have the necessary system objects to poll for available and free memory. You will not be able to use HUM to poll its memory stats.
tech_trac Sun, 09/27/2009 - 12:02
So is there any other way by which I can record the ACE Memory readings for historical reporting etc.
Joe Clarke Sun, 09/27/2009 - 13:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Not using SNMP. You would need to use some screen-scraping tool to parse CLI output.
tech_trac Mon, 09/28/2009 - 01:50
Can TCL Scripting on ACE be used to achieve this.
Joe Clarke Mon, 09/28/2009 - 07:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I'm not that familiar with scripting on the ACE platform, but I believe the scripting was only for manipulating SLB characteristics.
