Changing URL services parameter from Enterprise Parameters Configuration
I changed the URL service parameter from the Entreprise Parameters Configuration page because it was pointing to a node IP address that is temporarily unavailable. I saved the config, however, on the 7911 ip phone HTTP CONFIGURATION still shows the old URL. A reset doesn't solve the problem. How could force ip phone to take into consideration the new config.
bets regards,
Jaime Valencia Thu, 09/24/2009 - 08:26
Try rebuilding the CNF files under the TFTP config so they get the new info
if this helps, please rate
