incoming and outgoing phone call logs
Answered Question
Sep 24th, 2009
Currently we are using Cisco CallManager ver.5.1.2.3000-2, Berbee InformaCast ver.6.1.1 and Cisco Unity 1.1 Build 10. When people place internal or external calls, does it create any logs? (Say if I made a call from ext:3809 to Florida or Europe or to another extension). What about incoming calls from outside our facility? Can I monitor it? If incoming /outgoing calls are logged, where is the log stored? If it doesn't, is there any way I can monitor incoming /outgoing calls or track the calls through logs?
Any tips/suggestion greatly appreciate.
Alex
Correct Answer by Jaime Valencia about 7 years 9 months ago
It can, you need to enable CAR to get this records. It's not enabled by default so if it's not enabled you'll only get info from the moment you enable it on forward
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 09/24/2009 - 07:55
  • Cisco Employee,
  • Hall of Fame,
    2011
java
