No Directory number assigned for IP communicator in CME
Sep 24th, 2009
I am using Cisco 2821 router Version 12.4(21), RELEASE SOFTWARE (fc1) as CME.When new IP communicator is registered with CME,no number is assigned but existing one is working without any problem even after reboot.
Is it any limitation on ephone or ephone-dn ? or any resource limitation issue ?
Nicholas Matthews Thu, 09/24/2009 - 06:22
Try this:
term mon
Then register your CIPC that doesn't work. It will indicate that a particular ephone number has registered.
Likely, you do not have a DN configured under that ephone. This could have happened if you mis-typed or misconfigured the MAC address.
Just find the ephone number it is regstering as, and add the dns to it.
-nick
Balasubramanian n Thu, 09/24/2009 - 07:55
I am trying to auto register a fresh IP communicator which the mac address is not configured already.
when a fresh IP communcator is trying to register,the event shows the ephone number.but if we login and look into that ephone number,there is no mac address.I need to add the mac-address manually to make it work.
