Getting a "constant" value into a custom parser
alec.waters
I have written several custom parsers, all of which extract source/dest IP and port from raw messages. They're all working fine in that respect.
What I need is for the MARS to also parse out the "protocol" value, which isn't present in the messages as they apply exclusively to TCP traffic. Can I have the MARS match on some arbitrary string and put a constant into the "protocol" field, rather than attempt to parse it out from the raw message?
many thanks,
alec
umedryk
Level 5
Level 5
The Parsed Field is one of fields of a MARS event that has been fully parsed.
Custom Parser: Patterns not displayed in the correct order it is bug.
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/4.2/user/guide/local_controller/cfgcustm.pdf
