3750 Stack Configuration
Answered Question
Hello All - I currently have a 3750 stack which is comprised of
1- WS-C3750G-48PS-E
2- WS-C3750G-48PS-S
3- WS-C3750G-48PS-S
I am planning on removing the two "WS-C3750G-48PS-S" switches from this stack and adding one
WS-C3750G-48PS-E switch into existing switch stack.
The steps I plan on taking to complete this intigration are list below
1- Shut down and remove stackwise cable from existing standard switches
2- make sure the IOS code matches the existing WS-C3750G-48PS-E switch and connect stackswise cables
3- Change the switch priority of the new switch to "1".
Is there anything else I need to consider when doing this reconfiguration?
Correct Answer by Giuseppe Larosa about 7 years 8 months ago
Hello Daniel,
it looks like correct only at step 1 may be easier to switch off the switch you are going to remove.
Another possible option is to provision the new switch before connecting it to current master.
see
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swstack.html#wp1177470
or
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swstack.html#wp1177470
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 09/24/2009 - 08:46
  • Hall of Fame,
    Founding Member
Hello Daniel,
see
or
Hope to help
Giuseppe
