How to install an MPE language pack
samalex22
Anyone know how to do this.. the documentation I've been looking up is pretty empty on instructions.. as is anything in the download
I need to add the Spanish Language pack.
testeven
Hi!
A secondary language for MPE needs to be licensed. The language pack file name is in the following format:
CUMPE_LanguagePack_la_LO-A.B.C.D.bin
where
la_LO represents the two letter language code and two letter locale code
A, B, C, and D represent the version number. The first three numbers (A, B, and C) in the version for the language pack file
must be the same as the first three numbers (A, B, and C) in the version for the system.
For example, the language pack file for Australian English is called
CUMPE_LanguagePack_en_AU-2.0.3.35.bin.
To find the language pack file, go to
http://www.cisco.com/public/sw-center/sw-voice.shtml.
There are 2 ways of installing a language pack on MPE:
1) Installing a Language Pack Using the Console
2) Installing a Language Pack Remotely
Please refer to the instructions for each method on the following document:
--> Release Notes for Cisco Unified MeetingPlace Express Release 2.0
http://www.cisco.com/en/US/docs/voice_ip_comm/meetingplace_express/2_0/english/release/notes/b_rn20.html#wp265343
HTH!
Teresa.
If it helps, please rate :)
Regards, Tere. If you find this post helpful, please rate! :)
